820-00138 Random black screen
tlough75
On the bench I have an 820-00138 that has a strange issue. The backlight flickers and turns off, or stays on. BKLT_EN_R is 3.3V and BKLT_EN_L is 11V when computer is turned off but when I turn the machine on BKLT_EN_L goes to 7-8V and stays, even if I close the screen down. Does this mean U7701 is toast. The backlight will randomly go out, then come back on, then stay off. Can't say I have ran into this issue much.
"BKLT_EN_L goes to 7-8V and stays"
If you mean LCD_BKLT_EN_L, perfect.
I recommend to test first with known good compatible LCD assembly.
The image still present when backlight goes off?
tlough75
yeah for the most part. It did glitch out once. By that I mean the Apple logo would come up then the screen would blink, then the Apple logo would come back. It did that about 5 times before I tried to shut it down with the power button, which is not working either.
tlough75
I get USB activity because I am booted from external drive. After the initial crash I have not been able to get it to do crash again, just the backlight issue remains. Going to see if I have a test LCD.
