820-00138 won't boot when SSD is connected
ajdoc
Cant find any corossion.
Board won't boot when PCIE SSD is connected (SSD controlled on SSD is hot).
After press power button fans are spinning (trackpad clicks, caps lock LED not working) and screen is blank.
As soon SSD is removed all works fine if boot from USB port.
Tested with known good SSD and same issue.
Checked both SSDs on another machine and SSDs are working fine.
Compared diode mode with working board of J3700 and all readings are correct.
Any idea?
ajdoc
Signals as well.
U3740/1 - 3.41V
U3740/2 - 0.99V
U3740/3 - 3.32V
U3740/4 - 3.41V
U3740/6 - 3.32V
U3740/7 - 0.0V
U3740/8 - 0.0V
R3740 is good?
Check diode mode at pin 24 of J3700, w/ and w/o SSD inserted; compare with good board.
Do the same for pins 7, 8 and 47-50.
ajdoc
R3740 is good
J3700/24 - the same values on known working board:
w/o SSD - 0.456V
w/ SSD - 0.386V
J3700/7 - the same values on known working board:
w/o SSD - 0.290V
w/ SSD - 0.290V
J3700/8 - the same values on known working board:
w/o SSD - 0.440V
w/ SSD - 0.387V
J3700/47 - the same values on known working board:
w/o SSD - 0.411V
w/ SSD - 0.411V
J3700/48:
w/o SSD - 0.650V | known good board 0.450V
w/ SSD - 0.650V | known good board 0.450V
J3700/49 - the same values on known working board:
w/o SSD - 1.750V
w/ SSD - 1.750V
J3700/50 - the same values on known working board:
w/o SSD - 0.433V
w/ SSD - 0V
Are these readings voltages???
PLEASE, stop writing "V" after diode mode readings.
Avoid any misunderstood.
ajdoc
Found something wrong.
One of C3710-17 dont match.
With SSD inserted on working board got diode mode reading 0.380 and on clients board got OL.
My 820-00138 boardview is in fact 820-3662 model and that area looks different .
Will show on photo below where got wrong reading.
It looks like it is C3717 on board view.
