I have 820-00138 yellow light doesn't charge,
I found few threads, having the same issue they are all closed without resolution on this forum. So I will give it another try. My board is beraly water damage. turns on with battery, when connect charger percentage jumps to 100% I tried pram reset before realizing it doesnt charge. and doesn't turn on with battery unplugged.
ISL6259 gets power
between pins
17/18 - 4ohm
27/28 - 15 m ohm
20v PPBUS
what I think L7560 - has only 1v
if I remove coil one side has almost short 250 ohm - P3V3S5_CSN2 is that normal or is it even L7560? I removed TPS51980 and resistance hasn't change.
1 photo of the element that had water damage. the other photo of L7560
ISL6259 gets power
between pins
17/18 - 4ohm
27/28 - 15 m ohm
20v PPBUS
