820-00163 PPBUS 12.2v no green light
No-Clean
Board had some nasty corrotion around and under U5010, traces got repaired and new U5010, but ppbus is 12.2v
U5010
Pin 1-3 3.1v
Pin 5 0v
When U5010 is not present I do get a green light and 12.56v on ppbus
Thanks
"U5010 "
Do you mean U5110?
If board starts without it, your problem is on its inputs, if still bad after changed it.
Change C5101 too.
Post all voltages of U5110.
Disconnect keyboard and try again.
No-Clean
Sorry yes U5110, the board doesn't start without it, but without it I do get 12.56v on ppbus and green light
New C5101 and same thing
U5101
1 3.1v
2 0v
3 3.1v
4 0v
5 0v
6 0v
7 3.3v
8 0.2v
Solve the problem of pin 6 first.
Pin 4 is also bad too...
Disconnect ketboard and check again.
If still bad, post U4850 voltages.
