820-00164 No power on
aurel476
Board no power on green light and orange light present but after few seconde return to green light and orange light again
Tried good magsafe 45w, io board and cable good know
PPBUS_G3H 8.53V
PP3V42_G3H 3.42V
PP3VRTC_G3H 3.29V
ALL_SYS_PWRGD 0V
replaced R7121, 7122 of U7100 because value too high
can you explain S0, S1, 2,3,4,5 state of power (how it's work, s0 started or state off for example)
What check after in order
aurel476
History no liquid damage, just stopped working
pins of U7100 :
17/18 : 3 Ohms
27/28 : 20.7 Ohms
PPBUS_G3H : 8.534V
PP3V3_S5 3.295V and PP3V3_SUS 3.294V
SMC_RESET_L steady high 3.387V
Check all RTC signals and post also PM_BATLOW_L, S5_PWRGD, PM_DSW_PWRGD, PCH_DSWVRMEN, SMC_ADAPTER_EN, PM_RSMRST_L and PM_RSMRST_L.
aurel476
checked all RTC signals : 3.298V
PM_BATLOW_L : 0.035V
S5_PWRGD : 3.387V
PM_DSW_PWRGD : 3.415V
PCH_DSWVRMEN : 3.201V
SMC_ADAPTER_EN : 1.048V
PM_RSMRST_L : 0V
Really the 4 (four) RTC signals same 3.298V?
"PM_BATLOW_L : 0.035V"
Original and correct charger for sure?
"SMC_ADAPTER_EN : 1.048V"
This is sign of SMC issue.
But PCH can pull it down too, less probable.
Post U8130 voltages.
aurel476
for rtc signals i check all point of PPVRTC_G3H i've got 3.298V
Original and correct charger sure
U8130 voltages :
1: 3.295V
2 : 3.295V
3 : 0.243V
4 : 3.269V
5 : 0V
6 : 3.265V
"i check all point of PPVRTC_G3H"
I said RTC "SIGNALS", not power rail!!!
Check page 12 (RTC block).
"PM_RSMRST_L : 0V
6 : 3.265V"
aurel476
PM_RSMRST_L : 3.265V sorry
for check signals i don't have oscilloscope,
page 12 i've PCH Decoupling
There are 4 RTC signals to check in DC, with a simple DMM.
To be more explict, even if is the "n" time I mention these signals: RTC_RESET_L, PCH_SRTCRST_L, PCH_INTVRMEN, PCH_INTRUDER_L.
Newest boards don't have the last two signals.
aurel476
thank you for information
RTC_RESET_L : 3.290V
PCH_SRTCRST_L : 3.290V
PCH_INTVRMEN : 3.201V
PCH_INTRUDER_L : 3.017V
Is PM_PWRBTN_L steady high?
Check it for drop pulse when trigger SMC_ONOFF_L signal; use R5115/16 pads, instead od power button.
If yes, check for pulse at all PM_SLP_Sx_L signals at same time.
Did you try SMC bypass mode?
aurel476
PM_PWRBTN_L : 3.406V
SMC_ONOFF_L : 3.415V no pulse stable
How use Bypass mode ? short R5115 or plug keyboard on power button many seconds while plugging charger ? (if i remember)
"no pulse when SMC_ONOFF_L pressed"
No pulse where???
SMC seems to work.
PCH should release (high pulse/level) all PM_SLP_Sx_L signals at the same moment of drop pulse on PM_PWRBTN_L.
