820-00165-02 - Won't Charge
menatwork
The computer works fine without the battery.
The thing is: I can't charge, bc when i put the battery back the computer don't turn on and i don't get green light.
Already check two different battery, so i'm sure thats not the problem.
Were i can start troubleshooting for give you guys idea what could be wrong with this board?
menatwork
U7100
1 - 0
2 - 16
3 - 4.48v
4 - 3.33
5 - 1.13
6 - 0
7 - 0.79
8 - 1.4
9 - 0.39
10 - 3.29 to 3.42
11 - 3.29 to 3.42
12 - 3.42
13 - 3.42
14 - 3.42
15 - 0.52
16 - 8.40 to 1 (after 3 seconds in loop)
17 - 8.40
18 - 8.40
19 - 5
20 - 5
21 - 0.54
22 - o
23 - 8.40
24 - 8.40
25 - 12.20
26 - 16v
27 - 16v
28 - 16v
menatwork
U7100
16 - 8.40 to 1v (after 3 seconds in loop)
C7126 - The same
Q7155 - Pin 4 the same
If the the voltage drop from the U7100 pin 16 (CHARGE_BGATE) all the line will drop too. I think the problem is U7100
I'm right, aprendiz dukefawks ?
menatwork
dukefawks Can u explain to me, why the voltage drop for 1v and then back to the normal state?
Thats is because the battery is not plugged?
larossmann
The only time anything remotely like this occurred to me was when a PPBUS_G3H high side mosfet was shorted and making PPBUS_G3H 16v. Seeing as your PPBUS_G3H is 8.4v, that is not the case here, so I have no idea either.
menatwork
larossmann I just get new measurements with battery plugged:
Q7155:
Pin 3-2-1: 8.62v
Pin 4: 1.13V
Pin 5: 8.61v
Right now the voltage dont drop.
Also, i don't get green light.
Do you think could be bad SMC?
