820-00165 3V instead of 3.3V on PPVRTC_G3H. DEAD CPU?
Hi.
I have a board with PM_SLP4 missing.
PPVRTC_G3H is at 3V and not 3.3V Is this indicative of a dead CPU/PCH?
Signal is coming from U0500. I'm not aware of any steps that comes before that.
18.5V 0.021A from PSU
PPBUS_G3H 8.59V
Oh I see. I struggle to see when a signal is inbound or outbound on the schematics :S
3V3_S5 2.908V
PP3V3_SUS 2.90V
Seems like all voltages are slightly off.
Try with 2K2 resistor instead of 10 ohm for R7563.
You can also try 9K1 instead of 10K for R7561.
Playing with feedback resistors, you can adjust correct 3V3_S5 voltage.
Replacing the resistors restored voltages and I now have a booting device!
I had already replaced the U7501 and measured DIODE mode up against OBDATA and everything checked out. I would never have been able to fix this board without your guidance.
Thank you! 2informaticos!
