820-00165-A A1466 2015
Pins 27/28 are connected through mentioned resistors.
If you disconnect any of R7121/22 shouldn't have conntinuity.
lincev
remove r7121/22 and solved
If I put in just one, everything is fine, but if I put in two, I have continuity again (resistance in good condition from other logic boards)
lincev
ok now I have :
pins 17/18=04.9 (scale 200)
pins 27/28=20.6 (scale 200)
i have continuity pins 27/28
It turns on, battery connected but when I disconnect MagSafe it turns off. Battery charges and percentage appears
lincev
I have done tests with the short in R6950 but its behavior has not changed
It stays on for a while sometimes for 5min voltage 8.05v when it turns off 8.15v
I have also noticed that when it fails despite having the battery connected it also turns on automatically when connecting the magsafe
It has been working for 10min false positive I turn off, disconnect the battery, reconnect the battery, connect magsafe and when disconnecting it turns off. If I leave magsafe connected for a while it turns on again and leave it for 1min and it stays on...
