820-00165-a BATTERY NOT DETECTED.
Dewanbd
This boards was water damaged working except battery not detected.
R5380: 26m ????
R5381: 2k
PPBUS_G3H: 8.2V with charger
diode mode
J6950 P4: 0.48
J6950 P5: 0.48
J6950 P6: OL
Any help please.
The battery could be bad. The Battery Management circuit could be damaged. I see this a lot in water damaged machines.
Check the voltage at the battery terminals with the power attached. Then check the battery plug with the battery unplugged. If it's dead there is your issue.
There is a fuse on the battery management board "requires you tear into the battery" that has ultra low melting point solder in it. I have seen these fail. I harvest these fuses for the solder and use it at chipquik.
If you have verified that the battery is good check the BMIC lines. In my experience it is usually the battery it's self.
"R5380: 26m ????"
What the "m" means, Megaohm???
In such case, change R5380
"PPBUS_G3H: 8.2V with charger"
In this case you have a problem on the MLB; this doesn't discard a battery issue.
Dewanbd
Changed R5380 now its ok ( 2k ohm) but still PPBUS-G3h is 8.18V
This is good battery works with other unit.
Change U7100.
Be sure battery connector is good and no corrosion under it; you may need to remove and clean/change it.
If still the same, change SMC...
