820-00165-A MagSafe light, fan spin, no image, no water damage
MaxFix
L3095 0V
L7520 5.13V
L7701 0V
L7560 3.36V
L7310 pin 1 - 1.97V pin 2 - 1.8V
L7320 pin 1 - 1.99V pin 2 - 1.8V
L7130 pin 1 pulsating 5.90V - 7.2V pin 2 8.6V
PPBUS_G3H is 8.6V and 3V42 is present 3.42V.
PM_BATLOW_L - 3.31V
PM_DSW_PWRGD. - 3.42V
PM_RSMRST_L - 3.03V
PM_PWRBTN_L - 1.0V
PM_SLP_SUS_L - 3.34V
someone knows how to proceed?
"PM_PWRBTN_L - 1.0V"
Are you really sure?
Do you get USB activity, or external video?
BTW, stop to check voltage on both pins of a coil.
You can find the output DC voltage on the pin connected to filter capacitor.
Did you try known good compatible LCD assembly?
Check if in the first seconds you get 3V at pins L8304; also check if coil is good.
You must get this voltage even without LCD, but will only stay present 2-5s.
If LCD is connected, DP_INT_HPD must go high at same time.
