You need to post more information here.
What voltages do you get with "damaged" battery?
How much time did work such battery, before dies?
Exact PPBUS_G3H voltage without battery?
What voltages do you get with "damaged" battery? which voltages only battery bad without charger?
How much time did work such battery?, before dies?around 1 month and bad battery comes back
Exact PPBUS_G3H voltage without battery? 8.6v
"What voltages do you get with "damaged" battery? which voltages only battery bad without charger?"
Both cases; battery w/ and w/o charger connected.
Also post voltage and diode mode on SCL/SDA lines of battery bus.
with battery and charger connected PVBAT_G3H_CONN=8.18V PPBUS_G3H=8.35
only batery=PPVBAT_G3H_CONN=7.35V PPVBAT_G3H_CONN=7.33V
only charger=PPVBAT_G3H_CONN=8.6vV
SCL=0.544 SDA=0.53 on j6950 pin 4,5 mode diode
I never bought Apple batteries on eBay.
I repair more for other services, they chnage the batteries when needed.
I have old original "known good" batteries in stock, only for tests; not for all models, unfortunatelly.
