820-00165 A1466 No battery
pipsystems
Board powers on and boots fine with charger, known good batteries display 0%, dies, and it does not charge.
Corrosion around C1204, and U6101 area
I tested the continuity on U6101 and all the connections seem to be fine still
Post exact PPBUS_G3H voltage, w/ and w/o battery connected.
Also check voltage and diode mode to ground at SCL/SDA lines of battery bus.
pipsystems
PPBUS_G3H:
8.62 V - Just Charger
1.8 V and dropping steadily - Just battery
5.99V - Bat & Charger
I'm sorry but I couldn't find the SCL and SDA lines related to the battery
Note: Sometimes the fan does spin fast and sometimes doesn't
This is what I did find related to the battery:
Just the charger connected:
NameVoltageDiode ( disconnected from power and red to ground)
CHGR_VNEG_R1.43V2.67V
PPBAT_R8.6V0.152V
PPBAT_CONN8.6VOL
TBT_BATLOW3.3V0.806V
PM_BATLOW3.3V0.5V & Rising
Just Battery Connected:
NameVoltage
CHGR_VNEG_R5mV
PPBAT_R1.6V
PPBAT_CONN1.6V
TBT_BATLOW15mV
PM_BATLOW37mV
Battery and Charger Connected:
NameVoltage
CHGR_VNEG_R0.98V
PPBAT_R5.95V
PPBAT_CONN5.9V ( Rising)
TBT_BATLOW3.3V
PM_BATLOW3.3V
Looks like battery is charging.
Let it connected more time and voltage should increase more than 6-7V ("5.9V ( Rising)").
"I'm sorry but I couldn't find the SCL and SDA lines related to the battery"
No idea, looking at battery conector in schematic???
These values should be good, as PPBUS_G3H is correctly controlled.
There should be bad battery, or broken connector.
