820-00165 ALL_SYS_PWRDGD Low
Instafixx
Hello,
I have a Macbook 820-00165. Customer said it isnt turning on. When it came to me it turned on just once for sometime and the dead.
Upon inspection i found corrosion at R8159 R8158 R8151 R8152.
Replaced them. Still no success.
I checked all the Power Rails.
I am getting PM_SLP_S3_BUF_L 3.3V at R8167 but ALL_SYS_PWRGD is at 0.6V. Thought it looked fine i replaced R8167 too.
Checked from crap below Q8150 as the corrosion was below it. But nothing there too.
Macbook is drawing around 180Amps.
Instafixx
Diode Mode Measurements of Q8150
Red to Ground
Pin#7 is 7.5K Ohms
Pin#6 is 160K Ohms
Pin#5 is 15.75K Ohms
Pin#4 is 1.5M Ohms
Pin#3 is 1.1k Ohms
Pin#1 is 20.7k Ohms
You can test removing Q8150; is just a redundant protection.
Post voltage on all big coils.
Check diode mode to ground on the ones with missing voltage.
I can't see any reason to quote an entire post, visible few centimeters above.
Write directly into reply box, instead of clicking Reply button.
Please, maintain forum aesthetic.
Q8150 monitors 3 voltages.
If all these are good, then you have problems with resistor dividers connected to Q8150 inputs.
No need to bother with that circuit in such case; just leave the chip unsoldered.
