820-00165 Board Repair
Instafixx
PPBUS_G3H is 8.57
PP3V42 is 3.4V
ALL SYS PWRGD is 0V
U1950 all pins 0 Volts
PP5V S4RS3 PULSING
PP3V3_S5 IS 3.3V
PP5V_S5 IS 5V
BOARD HAS BEEN WORKED UPON PREVIOUSLY.
A FEW COMPONENTS MISSING WHICH WERE RESTORED. (C1260/1/2)
SMC ALSO REFLOWN/CHANGED
"U1950 all pins 0 Volts"
Pin 8 MUST have voltage; is directly connected to 3V42_G3H.
Rebuild broken trace...
"PP5V S4RS3 PULSING"
Any big coil pulsing at same rithm?
Check in SMC bypass; this should provide higher pulse.
Do you get 1-2 pulses, or continuously every 5s?
So you get pulse on CPU core too.
Check for pulse at pins 7 & 3 of U1950; also PLT_RESET_L.
Please, use capital letters when really need only...
Possibly CPU issue.
Check all SPI Bus Series Termination resistors and their traces.
Inspect J6100 for corrosion.
Heat CPU with quality flux; in case of accumulated crap underneath.
