820-00165 Drawing 3 Amps
tlough75
Got an 820-00165 on the bench with no sign of liquid damage. The board works but when I connect to 85W magsafe it will not turn on. It will turn on with either a 60W or my lab bench PSU 85W plug made from genuine MS2. I checked the ISL and SCL, SDA lines and they measure .529 on Diode and 3.42V. I tried other batteries but still draws 3 Amp with battery plugged in.
Run HWMonitor and look at voltage and current sensors.
Does it turn on with 85W, in SMC bypass mode?
tlough75
Things that stand out to me in HW Monitor are:
PECI SA is 0 degrees
CPU VRM E is 0v
Mainboard S0 Rail is 2.89A
Memory module 1 is consuming 1.07W
Battery is charging, just drawing 3Amps of current.
tlough75
It turns on in SMC bypass mode with the 85W on the bench PSU, but not the one that plugs into wall. BTW I strictly use OEM MS2 chargers purchased from a store.
tlough75
Sorry, I meant it will NOT run on a 60W charger. In fact, the only charger is DOES work on is the one that is hooked up to my Bench PSU. It will not run from an 85W, 60W, or 45W MS2. U7100 or U5000 issue?
tlough75
R7180: 100K
R7181: 62.7K
R7185: 470K
R7186: 331K
D7012: 6.83V
I had to replace D7012 just now as it broke. is working with PSU 85W and regular 60W but not 85W
tlough75
Was getting 0v, started measuring components at the beginning of the charging circuit and found R7012 was reading 440K. Replaced it, now running off of all chargers with a green/orange MS2 light. Still have another issue though. The charge current still wants to run away. It starts low then ramps up to 3 Amps, which is the limit for this power supply. So far I have replaced D7012 and now R7012. Still have some hunting to do. I swapped a different board for the client so this one belongs to me now.
"Nope, original MS2."
Where did you see the 3A current then?
Use original Magsafe 2 CHARGER, not only cable!!!
