Hi guys
Very tiny liquid damage.
Macbook came in with a problem on SMC Reset. Everytime the power button was triggered, smc will perform a reset and macbook will not start .
I Fix it and now it works but fans goes high speed.
Tested with only trackpad, I/O Board, fan connected.
Already tried changing trackpad & flex.
Fan goes high rpm when loading MacOS but stays low rpm with SSD disconnected.
(So the issue is when it switch in SPI, right?)
U4810 goes to correct value when OS is loading....
Pin 1,3,5,6,8 =3,3v
Diode mode measuring on J4800 are OK compared to another working board.
No Issues found in AHT.
All temperatures ok on HWMonitor.
Macbook speed seems regular.
In system preferences- Trackpad , no device can be seen, so no personalization is avaiable. But trackpad works with no issue.
In system report - SPI - I can see the trackpad listed.
R4850-4851-4852-4853 are ok.
Can be ME region corrupted? No one touched U6100 before...
Pin 1,3,5,6,8 =3,3v
