820-00165 fan NOT spining
Bouba148
Hi RRG team, folks
I have a 820-00165 which had a liquid damage around the U7600 area ( i had to replace some resistors and rebuit some traces) and also liquid around U6100 and 6101.
Green light ok main rails all OK until it arrives around U0500 so I' ve checked all the resistors and traces involved in the "SPI Bus Series Terminaison" : All OK
Then I suspected /conclued that it was certainly the U6100 so I've replaced it then the board turned ON (Fan spinned ). New SPI rom ordered from ebay with Clean ME Region and serial injected/wrote by the Vendor.
Once I've replaced the board back in the chassis and replugged everything, it turned ON: Chime, display , backlight, No Over Heating, all OK except the fan does NOT spin, I did an SMC and PRAM reset without effect.
I think that i'll disconnect elements one by one and try, if not i'll take it out from the chassis and retry it on the desk.............
In the mean time any clue is welcome.
Thanks in advance
Bouba148
Hi Dukefawks, Aprendiz
Before ordering the bios chip, i've asked and mentionned how important it was, and they confirmed me that the ME Region is cleaned.
Also I have a TL866 programmer , a supposed good bin file but asked you guyz a clear procedure how to do it. Because what i've found on the web is not "clear", specially for 00165.
Before soldering it i've done a backup of it, i can post it to you in PM if you want, then you can confirm me if the ME Region is clean.
Dukefawks if you don't mind could you please post a procedure or message me in private. It's as you wish: I really want to learn how to do it.
Bouba148
OK Thanks but it could not be done with a programmer like TL866?
By the way, you can mark the topic as solved: the Fan flex cable wasn't secured because of missing latch on the connector.
Bouba148
hi Team,
This board came back, just to remind you that the original issue was the board was not turning ON because of water damage around U6100 and U7600: replace U6100 and reworked the U7600 area ( check my first post ).
Now it came back because of the fan running at full speed, after intalling MACS Fan Control it appears that none of the sensors is showing overtemp ( check attached pictures ), in fact if I touch the board nothing is getting hot.
Once in that application I've set manually the speed to adjust itself to the GPU which has the highest temp (36 deg), then te fan ran normally. But if I set it to auto it immediatly runs at full speed......
I did PRAM and SMC Reset without succes.
should I run ASD? I there anything to check/test before......?
Bouba148
Also first it was turning OFF after around 10 min with fan at full speed, now it stays ON.
I've of course cleaned and changed the thermal past.
Here are the pictures sorry:
Click image for larger version  Name:	DSC_0788.JPG Views:	1 Size:	1.23 MB ID:	41160
Bouba148
OK thanks ..
Before you replied i saw that there is no ASD
​​​​​​. I'll try to clean the ME and let you know.
Thanks
