820-00165 fan spins, flashing folder, tried good SSDs, not seen by diskutil
Outofwhack
Initially no fan spin, 33mA draw and very clean board except slight corrosion around R7611, cleaned up and got fan spin but left with flashing folder.
pp3v42_g3h 3.4v
ppbusg3h. 8.9v
draws 780mA
pp5v_s5 5.09v
pp5v_s0 5.3v
ssd_pwr_en 3.3v
smc_pwrfail_warn_l 0v
ssd_pcie_sel_l 0v
smc_oobi1_r2d_conn_l 3.3v
smc_oobi_d2r_conn_l 3.3v
p1v05_s0_vref 1.8v
p1v05s0_fb 1.05v
pp1v05_s0 1.05
ssd_reset_l 3.3v
ssd_clkreq_l 0v
ssd_clkreq_conn_l 0v
pp3v3ssd_vmon 1.02v
ssd_reset_conn_l 3.3v
U3740 OR-gate seems suspect to me with OR -gate input pins 6 at 3.3v and pin7 at 0v and output pin 8 at 0v (but another 00165 board I have gives same result)
I can boot from high Sierra or El Capitan install media on USB drive but cannot see internal SSD in disk util.
Any ideas?
"U3740 OR-gate seems suspect to me with OR -gate input pins 6 at 3.3v and pin7 at 0v and output pin 8 at 0v (but another 00165 board I have gives same result)"
Zoom in the pdf and look at OR gate input corresponding to pin 6...
"smc_pwrfail_warn_l 0v"
Can you compare with good board?
I expect 0V to mean failure; signal name ends in "_L".
Possibly corroded traces, or components related with SSD connector.
Outofwhack
smc_pwrfail_warn_l is also 0v on another board I have so I think I will assume this is normal.
Wow well spotted, after I zoomed to 800% I can see the negation!
Compare diode mode to ground on all SSD lines, with good board.
Do it with the same SSD connected in both.
Don't forget to check on both side of C3710-17 and U3710/11 data pines.
The connector has hot plug detect capability (HPD) for display port.
Detection is done by hardware.
