820-00165 Green/Amber light, no fan spin.
gfosterCA
Board removed, testing with DC-in board, fan only, using 85W magsafe 2 power adapter.
PPBUS_G3H - 8.6v (8.596)
PPBUS_S5_HS_COMPUTING_ISNS - 8.6v
PP3V42_G3H - 3.4v
P3V42G3H_SW - 3.42v
L7560 - 3.35v
L7520 - 0v
P3V3_S5_DRVH - 3.38v @ Q7560 pin 3
P5V_S4RS3_DRVH - 0v @ Q7520 pin 3
Help is very much appreciated!
Any fault history available?
Post SMC_ADAPTER_EN, PM_BATLOW_L, PCH_DSWVRMEN, S5_PWRGD, PM_DSW_PWRGD, 3V3_SUS voltage.
gfosterCA
Post SMC_ADAPTER_EN, PM_BATLOW_L, PCH_DSWVRMEN, S5_PWRGD, PM_DSW_PWRGD, 3.35v voltage.
Thanks for the welcome!
Customer reported machine just stopped booting. No real evidence of liquid damage or major corrosion that I can see.
SMC_ADAPTER_EN = 3.39v
PM_BATLOW_L = 3.35v
PCH_DSWVRMEN = 3.26v
S5_PWRGD = 3.40v @ U7501 pin 20, and right side of R8141
PM_DSW_PWRG = 3.42v
3V3_SUS = 3.35v
Trigger SMC_ONOFF_L and check for drop pulse at PM_PWRBTN_L (at same time).
BTW, write directly on the reply box, instead of clicking Reply button.
I don't see any reason to quote an entire post, visible few centimeters above.
Please, maintain the forum aesthetic...
gfosterCA
Apologies on the poor reply form!
I'm assuming triggering is grounding SMC_ONOFF_L.
If so, I am seeing :
PM_PWRBTN_L drop from 3.41v -> 0.34v
Touch the ground only a moment, like when press the power button to start.
Now check for pulse at PM_SLP_S4_L (at same time also).
Do you mean PM_SLP_S4_L drops to 0.34V when trigger SMC_ONOFF_L???
It should pulse high, not droping...
gfosterCA
PM_RSMRST_L = 3.32v
PCH_CLK32K_RTCX1 = .37v
RTC_RESET_L = 3.34v
PPVRTC_G3H = 3.35v
PPVOUT_S0_PCH_DCPRTC = 1.58v
There are many more components connected.
If pure short, you can use voltage injection to detect the culprit.
BTW, read this thread about RTC signals...
gfosterCA
Great read, thank you.
Looks like L1275 is shorted. Also getting shorts at C1280,C1280 and L1280.
Before I go too far down the rabbit hole, is this a good indication of a CPU that's toasted itself ?
One coil measure short as normal.
It never can generate a short to ground.
Remove the coil and see where the short to ground remains.
gfosterCA
Thanks for the guidance on this. Have another with what I suspect to be an SMC problem. Will tackle that in a new thread.
