820-00165 Green led but not start
raainxx
Hi, i have this board no liquid spill, i have PP5V_S5 = 1,2V, in diode mode 0,447 (bad), i try to change U7501 but same problem.
i don't understand where the PP5V_S5 is generated, by U7501?
Why do you think 447 is bad?
Doesn't look low at all.
Do you get SMC_PM_G2_EN and correct PPBUS_G3H?
Check 5V_S5 disconnecting trackpad flex.
If still bad, change U7501.
As last step, change U7400 if needed.
raainxx
PPBUS=8,59V
SMC_PM_G2_EN=3,41
sorry i say bad for 1,2V i have just the board with magsafe board and cable flex.
i remove U7400 same problem, i change again u7501 and i come back
I hope you didn't power up the board without U7400!!!
Remove C7505, C7410, C4810 and check again 5V_S5.
raainxx
i power up the board without U7400, is it dangerous? because i haven't PP5V_S5. i dead the board?
I remove C7505, C7400 instead of C7410, C4810, same 1,2V on PP5V_S5
Doesn't look bad, you could be lucky.
Check diode mode on all 3V3 and 5V power rails; from S5 to S0.
Check all traces, solders and components around U7501.
raainxx
I check all rail 3V3 and 5V
PP5V_S5=0,465
PP5V_S0=0,412
PP3V3_S5=0,564
PP3V3_S4=0,381
PP3V3_S3=0,465
PP3V3_S0=0,341
PP3V3_S4SW=0,486
i check trace nothing, solder and component around U7501 seems good, i compare with another board.
Maybe i use bad U7501 from donor board?
raainxx
ok thanks, i solve the problem, i think i remove by mistake C7503, when i change U7501 the first time.
Now the mac work well.
"Check all traces, solders and components around U7501.
i check trace nothing, solder and component around U7501 seems good"
Pay more atention in the future...
