820-00165 J3501 replacement
Kyle93
Arrived with liquid damage. Powers on and boots now but having wifi issues.
There was corrosion on the pins of J3501 After cleaning up J3501 pins wifi will work for a few minutes then turn itself off. After cleaning several times only to have wifi work for a few minutes before turning off again decided to removed J3501.
There was heavy corrosion on same of the pads. Now that the area is cleaned up what is a good method for soldering on replacement J3501?
Tried hot air a few times but the plastic keeps melting. Is there a certain temperature and airflow recommended?
