820-00165 - Minor damage on/around Q3510
nelo1012
There was damage on Q3510, R3512, so i replaced those two, and also replaced U3510,
When i plug in charger after about 5 seconds fan does a small kick/spin,
Any ideas, thank you guys in advance
PPVCORE_S0_CPU: 0V
PPVCORE_S0_AXG: 0V
PPBUS_G3H: 12.59V
PP3V42_G3H: 3.431V
PPVRTC_G3H: 3.336V
PP5V_S5: 5.035V
PP3V3_S5: 3.341V
PP5V_S4: 0V
PP3V3_S4: pulses twince when plug in then drops to 0.50v
PP5V_S3: pulses twince when plug in then drops to 0.0v
PP3V3_S3: pulses twince when plug in then drops to 0.50v
PM_SLP_S4: pulses once at plug in
SMC_BC_ACOK: 3.4V
SMC_PM_G2_EN: 3.4V
PM_BATLOW_L:3.32v
SMC_ADAPTER_EN: 3.4V
PM_SLP_SUS_L: 3.32V
SMC_ONOFF_L: 3.429V
Check if all secondary coils pulse; maybe not from CPU.
ALL_SYS_PWRGD pulses too?
Use R5115/16 pads instead of power button.
Check signals reaction every time.
Try to start in SMC bypass also...
nelo1012
ALL_SYS_PWRGD - when i plug power cord pulses 3.4v twice then stops.
when i use R5115/16 pads ALL_SYS_PWRGD goes to 0.57v then back to 0v
pardon my stupidity, but i do not know how to start in SMC bypass :(
Press power button (or use R5115/16 pads instead), connect magsafe and mantain pressed 5-10s.
Google also knows that...
smiba
How about SMC bypass like was asked? Do this by disconnecting all power sources (Battery + Magsafe) and having the power button pressed (or with R5115/16) while plugging the charger in. Keep the button pressed until the device powers on, if it doesn't do that after 15 seconds you can give up because it should've started already. Make 100% Sure the power button (or eqv.) is pressed when any power source is applied or the SMC will be booted and you would need to disconnect all power again first
