820-00165: Missing PP5V_S4RS3
Board came in with corrosion on U7600 and U3200. Cleaned and replaced both, but still not powering up.
I'm missing PP5V_S4RS3 - 0v
PP3V3_S5_REG_R is present at 3.3
When attempting smc bypass, the fan spins for twice for about 2 secs each time and then stops.
Any suggestions?
When in SMC bypass, all voltages try to appear?
Check all big coils and ALL_SYS_PWRGD too.
Be sure to get AVREF_SMC voltage.
Test board alone on the desk; no LIO flex connected, nor trackpad.
Check 3V3_SUS, PM_BATLOW_L and PM_DSW_PWRGD.
PP5V_S0 - tries to come on. Goes up to 0.7 then drops (same as with the fan coming on and off)
All the coils are doing the same thing as PP5V_s0 as the pulse up and down, except the lcd backlight which expected since the display is not connected.
ALL_SYS_PWRGD - goes up to 1.6 before dropping out as well.
AVREF_SMC - 3.3 the whole time. never drops out
Same result with LIO flex not plugged in
3V3_SUS - 3.3
PM_BATLOW_L - 3.3
PM_DSW_PWRGD - 3.4
"All the coils are doing the same thing as PP5V_s0 as the pulse up and down"
Even L7310/20?
Pin 3/U1950 pulses to?
In normal mode, check SMC_DCIN/PBUS_VSENSE and SMC_DCIN/BMON_ISENSE.
Yes, it also pulses on L7310/20 and Pin3/U1950
SMC_DCIN_VSENSE - 2.8
SMC_PBUS_VSENSE - 0
SMC_DCIN_ISENSE - 0.027
SMC_BMON_ISENSE - 0
