820-00165 no backlight
No-Clean
I know no backlight....
I watched a few videos and have learned some but I cannot get this board to give me backlight.
Replaced Q7706 and U7701 and nothing.
BLK_PWM is 0.509v even after replacing U7701
BKL_PWM controls U7701, not viceversa!
Post BKL_EN level too.
We need more info to help.
Post voltage and diode mode to ground on both pins of D7701.
Be aware of XW7720; pictures can be found on the forum.
Do you get image at least (on internal LCD)?
External video OK?
JohnB8812
No we do not. Please only reply. Let me be more clear. Post voltage on C7797. If 8.59 volts, then something wrong with feedback/the LED driver.
If you've changed U7701, post now diode mode (red probe at ground) on all return resistors.
Do PRAM reset few times.
If BKL_PWM still low, then remove R7704 and run a wire from R7715 to C7704.
Check if backlight comes on.
No-Clean
JohnB8812 C7797 indeed is 8.56v
2informaticos all return resistors measure 0.630
R7704 is 0.504v
I ran a wire from R7715 to C7704 after removing R7704 and no backlight either, folder with question mark flashes when I use a flash-light but no backlight yet.
