820-00165 no fan
VinceLx
The board looks ok, no fan, power supply gives 20-30mA
PP3V42_G3H=3.44V
PPBUS_G3H=8.6V
PP5V_S5=5V
PP3V3_S5=3.3V
PP5V_S4=0V
PP3V3_S4=0V
SMC_S4_WAKESRC_EN=0V
PP1V2_S5_SMC_VDDC=1.2V
SMC_BC_ACOK=3.4V
SMC_RESET_L=3.4V
What should I check next?
VinceLx
PM_PWRBTN_L goes from 3.4V to 0.35V as long as SMC_ONOFF_L is shorted to ground
Power supply goes shortly from 30mA to 50mA, nothing else
Do the same for PM_SLP_S4_L?
If pulse present, check for pulse on all power rails controlled by PM_SLP_S4/3_L.
VinceLx
You mean the same for PM_SLP_S3_L? There is also a brief pulse from 0 to 3.4V
Power rails:
from PM_SLP_S4_L :
P3V3S3_EN
P1V8S3_EN
DDREG_EN
all have a pulse at 3.4V
from PM_SLP_S3_L :
CPU_VCCST_PWRGD: pulse at 1V
P5VS0_EN
P3V3S0_EN
P1V05S0_EN
Yeah, you confirmed enable signals.
Don't you want to know if corresponding power supplies send out correct voltage too?
VinceLx
I tested in SMC bypass mode, fan spins 1 second when triggering SMC_ONOFF_L
Power supplies have pulses:
PP3V3_S4: pulse 3.3V
PP3V3_S3: pulse 3.3V
PP1V2_S3: pulse 1.2V
PP1V8_S3: pulse 1.8V
PP1V05_S0: pulse 1V
PP5V_S0: pulse 5V
PP3V3_S0: pulse 3.3V
VinceLx
Pulse on pin 7 ok, no pulse at pin 3.
I had pulses on SMC_DELAYED_PWRGD, but not at each trigger of SMC_ONOFF_L
Removed U1950, I got a couple of pulses on SMC_DELAYED_PWRGD, then no more. Do this pulse should appear at each SMC_ONOFF_L trigger?
R5191 ok
Fan spins first low speed a few seconds then high speed when I put the scope probe on pin 7, with power supply giving 200mA
What can I do about SMC_DELAYED_PWRGD not always there?
VinceLx
I tied them without U1950, and for some reasons I had pulses on SMC_DELAYED_PWRGD
Reinstalled U1950, I could start the board (blinking folder) by triggering SMC_ONOFF_L, with power supply giving 700mA, a bit higher than normal. The board did not start alone when giving power.
When trying later again: impossible to start.
Then I tied together pins 5 & 6 with U1950 present, I have pulses on pins 7 and 3, but the board does not start, SMC bypass or not, just fan spinning 1 second, as before.
VinceLx
Finally found a tiny corrosion spot around C4090 C4691 linked with PP5V_S4RS3, which gave also a pulse previously. Cleaned around and now the board starts alone, let's see for how long.
Thanks for this very detailed investigation! Always learning
VinceLx
Cold, the board does not want to start. Again, no pulses on SMC_DELAYED_PWRGD
I tied again together pins 5 & 6 with U1950 present, I have pulses on pins 7 and 3, but the board does not start, SMC bypass or not, just fan spinning 1 second, as before. Don't know where to go. It worked, I could boot in a SSD, but now dead again
