820-00165 No image, Chime, Minimal USB Activity
EMS05
I have an 820-00165 board here with no chime
USB flashes for half a second when first plugged in, no activity after that
All CPU power rails measure normal, and CPU gets warm
PLT_Reset_L is 3.3v
PLT_RST_BUF_L is 2.8V
Tried swapping a known good BIOS chip onto board, no change. Original has been reinstalled
Any pointers? I've never dealt with an issue like this, not entirely sure where to look
Thank you!
Any fault history available?
Check all SPI Bus Series Termination resistors and their traces.
Also clean/remove J6100, if corroded.
Be sure to get all voltages from page 11.
Laptop suddenly died, no history of liquid or drop. Looks brand new
All SPI Termination resistors and traces test good
Voltages on page 11 being the list of rails / signals under "CPU New Properties"?
I suspect another component, or trace corroded; as you already found R6114 bad.
If not, bad CPU.
Heat PCH/CPU with quality flux; in case of accunulated crap underneath.
