820-00165 NO KEYBOARD OR TRACKPAD
2click
Hi, this board is turning on, but when I get to the login screen, trackpad and mouse, just don´t work... But if I press ALT when the computer is starting, they both work, so it is not the keyboard nor the trackpad.
PP5V_S4_IPD = 5.1
PP3V3_S4_IPD = 3.3
SMC_LSOC_RST_L = 3.4
SMC_ONOFF_L = 3.4
never seen one like this...
2click
R4850-53 ARE OK
U4810
1 = 3.3
2 = 0
3 = 3.3
4 = 0
5 = 3.3
6 = 3.3
7 = 0
8 = 3.3
2click
The trackpad and keyboard work fine, I used a different board to see if it worked, and it did just fine...
Then you have problems with trackpad connector, o a TPAD_SPI data line.
Just in case, check/replace R/Q4860.
2click
I replaced R4860 and Q4860 still the same... I checked all TPAD_SPI lines and all seems to be good, the resistors have their values... no open or broken resistor...
2click
I don´t see why to change the connector, when I start the computer pressing ALT (Option) key, mouse and keyboard work fine, even the CAPS green light works, as soon as I leave the boot menu and the system starts loading I loose them both... worth reflowing the PCH ?
Before loading macOS drivers, trackpad works in USB mode.
After that, PCH enables SPI mode.
So should be PCH issue, or bad contacts on the SPI lines.
