820-00165 no power. PP5V_S4RS3 (NO PRESENT)
juhusu
820-00165 no power.
PP5V_S4RS3 (NO PRESENT) 0.000V and diode mode 0.440V
SMC Bypass mode: two fan sping two time 400mA pulse when connect charger (Orange light) Then 24mA constant
7100
Voltage whit out Battery
01-0.004V
02-19.58V
03-5.267V
04-3.326
05-1.096-1.106V up-down-up-down....
06-0.000V
07-0.791
08-1.433-1.438V up-down-up-down....
09-0.037V
10-3.403V
11-3.403V
12-3.427V
13-3.396V
14-3.396V
15-0.000V
16-8.56-1.305V
17-8.58V
18-8.58V
19-5.075V
20-5.038V
21-0.544V
22-0.000V
23-8.59V
24-8.76V
25-12.98V
26-19.19V
27-19.48V
28-19.48V
Diodo Mode
01-0.665V
02-0.639V
03-0.554V
04-0.488V
05-0.734V
06-0.148V
07-0.733V
08-0.554V
09-0.729V
10-0.544V
11-0.547V
12-0.335V
13-0.527V
14-0.500V
15-0.734V
16-0.681V
17-0.139V
18-0.142V
19-0.470V
20-0.472V
21-0.475V
22-0.000V
23-0.138V
24-0.592V
25-0.588V
26-0.663V
27-0.632V
28-0.619V
Don't waste time with U7100, if you get correct PPBUS_G3H.
Dp you get only two pulses, or power cycling every 5s?
VCORE and PLT_RESET_L pulsing at same time?
Any history fault available?
3V3_S5/SUS stable?
Inspect Q8150 and U1950 for corrosion.
Check all SPI Bus Series Termination resistors and their traces.
Clean/remove J6100.
Try known good BIOS, just in case.
juhusu
All SPI Bus Series Termination resistors and traces are good. I don't have another 820-00165 that I know of that works well.
I extracted the bios and saved the original .bin.
Can I do a Clear ME or something similar?
juhusu
Sorry but I'm new here. Please can you tell me where I can find those files or send me a link for it? thanks for everything Master.
juhusu
thank you master. that doesn't work for me. What I could see is that PP5V_S0 is missing. What do you recommend? Thanks.
Reball SMC, as basic step for boards where corrosion is noted.
If doesn't hekp, try heating CPU with quality flux; 10-15s, untill 180-200 degrees,
No need to melt the balls, just to burn eventually accumulated crap.
