SPKRAMP: New IO on the way in case all my IO boards are fucked which is possible I guess.
HDA lines on J9500 no shorts.... Are you asking exact drop across each?
AUD_PWR_EN high.
I live in hope that I am a complete numpty without a working OI as I may have swapped them all out. Get back in a couple of days. Actually amazed this board boots at all
Thanks for your help
SHDN low
Just found that a pads that "looked" there, are actually not there. SHDN and GAIN
I will replace U6410 and test diode mode etc.
Double checked continuity to all pins to J9500 back to anything audio and all good. Resistors OK, no shorts.
No headphones, is bluetooth, internal is recognised and volume shift.
Analog section of the audio chip must not be powered. Only power source I see for that is pin 9 or 28. See if R9501 is really no stuff and check continuity of pin 9 through the connector/cable to the io board.
