820-00165 No Video
iClub
This mac has suffered oxidation on the SMC and U5110.
Chime, activity on USB, but no image, only on external video.
I used a good display.
EDP_PANEL_PWR 0V.
Do you get 3V at pins 18/19 of J8300 in the first few seconds, when chime?
If yes, pin 14 should go high at same time.
Check for pulse there without internal LCD connected.
If not present, check if EDP_PANEL_PWR pulses at the mentioned time.
iClub
'' If not present, check if EDP_PANEL_PWR pulses at the mentioned time. ''
0V, no pulse when mac has the chime.
DP_INT_HPD_CONN 0v, no pulse.
iClub
No display connected EDP_PANEL_PWR 652mV pulse.
mode diode 0,631V
Looks like PCH problem.
Inspect for other corroded components.
Possibly accumulated crap underneath PCH/CPU; heat it as usual.
