820-00165 PCH_INTRUDER_L 2.1V
No-Clean
I have a few boards from the past that all have the same problem:
PPBUS 8.6V
5V_S5 5V
3V3_S5 3.3V
PPVRTC_G3H 3.3V
But PCH_INTRUDER_L is around 2V and PCH_INTVRMEN is around 2.1V on ALL of them I have tried to force the signal with a 100K resistor, the voltage goes up to 2.9V (I am not sure if this is in range of a good signal) but after that the board still does not boot, what else should I check?
These signals come through high value resistor, which generate a voltage divider with multimeter's input impedance.
Your problem is not related.
Do you get 3V3_SUS?
If you catch it, check for pulse at PM_SLP_S4_L (at same time).
No-Clean
I do get a drop pulse on PM_PWRBTN_L
PM_SLP_S4_L is 0V when I trigger SMC_ONOFF I get a fast pulse that goes up towards 3... volts then drops down to 0V
No-Clean
Ok discover that R7121/22 were blown, Im not sure if it was cause my LIO board was old and a little bit corroded, after replacing those resistors and testing with a different LIO board still same problem.
L7130 and L7560 are steady all other 0V, no pulse.
PM_SLP_S3_L 0V, pulses once when plugging charger then goes down to 0V and stays there.
SMC bypass same problem.
If both PM_SLP_S4/3_L pulse, you should catch pulses on all coils.
Check U1950 pins 7 & 3 for pulse.
Also check ALL_SYS_PWRGD if pulses.
No-Clean
PM_SLP_S3_L = 0V, pulses once when plugging charger then goes down to 0V and stays there so no pulsing here, just made the commend for reference.
U1950 pins 7 & 3 both 0V no pulse
ALL_SYS_PWRGD 0V no pulse
You must check at same time when pulsing PM_SLP_S4/3.
Trigger SMC_ONOFF_L and check for pulse on mentioned points and coils.
No-Clean
Board came in before but worked after a few measurements taken, now it is back again.
When I trigger SMC_ONOFF the board almost boots all the way and CPU seems to start to work, but shuts down shortly after.
PLT_RESET_L pulses to when I trigger SMC_ONOFF
May have accumulated crap underneath CPU/PCH.
You can try to heat using quality flux.
Maybe reballing SMC too...
No-Clean
Heating with good flux did not work, but booted once, that gave me hope so I did a complete reball of the CPU and now it is working constantly, thanks!
