820-00165 PP1V35_CAM Shorted
No-Clean
Clean board in S0 state U3900 heats up as PP1V35_CAM is shorted, I replaced the U3900 chip but the short comes back after I install a new U3900 with U3900 removed the short is gone, U2800 also gets a little hot.
I am puzzled with this board.
No-Clean
Removed U4000 short still there, replacing U4000 at this point will be useless.
One thing to note is that it is hard to remove U3900 without damaging it, the solder is very hard to come to melt and by the time you remove it you may have fried the chip, so to remove it from donor board I applied max hear and air from under the donor board and eventually it comes off without damaging the chip, then reball the chip with 183c paste and install it with 365c and no damage should occur to chip, but in my case I have tried 2 chips and short still there.
No-Clean
Ok some of my donor boards were also shorted on that same line and I did not bother to check and end up installing 2 bad chips, finally I checked and found a good one, short gone but now board makes it to S0 state but no boot.
PP1V05_SUS 1.5v
PP1V5_S0 1.5v
PP1V05_S0
PP1V05_S0 0.35v
ALL_SYS_PWRGD 0.06v
