820-00165 PP3V3_SUS pulsing 1.1-1.4V
BCN_Techs
Got this board with water damage near U6100.
Changed U7600, U6101, U7400 and some small components near that had wrong values.
Now all main rails are ok, but all rails near efi chip are pulsing from 1.1 to 1.4 V. Board is trying to enter S0 and all S0 rails are pulsing (Ex: 3v3_S0 is pulsing 0.5-0.8.)
I tried new bios DUMP and same. Without bios it is pulsing too. Checked traces and all are ok.
What else i can check?
Is not BIOS issue.
PCH doesn't access BIOS before PLT_RESET_L goes high.
Did you try SMC bypass mode?
Did you reball SMC?
BCN_Techs
SMC By pass not turning on
Right now trying reball smc because i see that also there is issue with pm_slp_s5_l. Will back once finish
ALL_SYS_PWRGD pulsing too?
Remove Q8150 and try again.
Check U1950 for corrosion; does it get pulse at pins 7 & 3?
If trigger SMC_ONOFF_L repeatedly, you must be able to catch higher pulses.
Need to be sure which points have pulse or not.
I'm talking about all power rails.
An o-scope can always catch the expected peak.
DC voltmeter will catch lower peaks, depending by the moment of the reading.
Repeated readings allow you to catch different values, some of them higher.
