820-00165 PP5V_S4RS3 pulsing.
Have this board that wasn't powered up and had corrosion. Cleaned up the corrosion and replaced damaged R8156.
PP5V_SR4RS3 pulses, so does ALL_SYS_PWRGD, PPVCC_S0_CPU, PLT_RESET_L and all the big coils.
SPI Bus Termination resistors good
I removed J6100 and also flashed know good BIOS with same result.
Any suggestions.
Remove Q8150 and test the board again.
Also test removing U8130.
Be sure no corrosion at U1950 and surrounding resistors.
