macRepairAmb
I have this board that i believe needs it's ram chips changed. I'm getting error PPM003/004 which points to an issue with the memory. I've checked for corrosion and found none.
As this my first ever ram replacement, my question, does it matter if the chip i used is of a different manufacturer but from the same donor board (820-00165)? The board needing fixed has chips from Skhynix but my donor boards has something else, which doesn't have a manufacturer name, just a pn, SEC740. Both the donor board and the board needing repairs are 8Gb boards. Only difference is the CPU, the board needing repairs is a 2.2GHz while the donor is a 1.8GhZ.
