D7005- starts at .8 and slowly rises to 1.6 and levels off there. Diode mode beeps on pp3v42_g3h rail. where would you recommend i inject power and check to see what gets hot?
alright guys i have weird issue with PP3V42 line... when J9500 cable is plugged in which it was while originally testing, the resistance to ground was .5 ohms. While disconnected its 53k. i noticed this becuase i diconnected the magsafe from the board when injecting voltage and pp3v42 wasn't drawing any current. while that cable is connected it draws max current. weird thing is even with freeze test with cable connect nothing is heating up.
tried with two different io cable with board. cable is on right way, and one of them was taken from a working computer... also noticed that the cable doesn't even have to be plugged into the io board. pp3v42 gets that way when cable i just plugged in by itself as soon as you plug in the flat cable.
okay removed the j9500 port and fixed the problem. computer boots up now. do you know anyone who sells them or am i going to be stuck having to buy a bad board from china to steal it from.
