820-00165 strange problem
Patricia
Thank you dos informaticos , I see that after 10 months I was away nothing changed , its still you who works :)
I did check the D7012 for a short and it was ok , and replaced the Q7180 and it is unfortunately the exact same symptoms , a short green light
every 3 seconds and on the desk power supply it works just fine :)
Thanks for the reply
Check if R7012 has correct value (ohm scale).
Also describe PPDCIN_G3H behavior, with original charger.
Patricia
R7012 is 68k , PPDCIN_G3H is starting with 5,2v and going down slowly to 3.9v , with desk power supply its 18.4v as it should be ....
Patricia
14.85 is the marked v on the charger but on the schematics its marked 18.5 v and that was what i refered to :)
The R7180 was hard to measure .... because it wasnt there :) Put in a 100k there and all works fine :)
Thank you dos informaticos for your help
Always respect voltage marked on the original charger.
You may trigger VD0R sensor sometime and SMC refuses to start in such case.
