820-00165 - there might be an issue with the camera
Alan.L
the board was liquid damage on U5620 and U5800,
an appeal, replaced these components and now the board boots fine. no high fan and no slowdown.
the camera is working fine on photobooth. however, ALS is not working.
The apple dialogistic confirmed "there might be an issue with the camera"
the camera connector looks great under a microscope. also tested with another known working display assembly.
diode mode reading on J4002
mipi_clk_conn_n pin2 0.397
mipi_clk_conn_p pin3 0.397
mipi_data_conn_n pin5 0.401
mipi_data_conn_p pin6 0.399
smcbus_smc1_s0_sda pin8 0.737 (0.507 on known working board)
smcbus_smc1_s0_scl pin9 0.739 (0.509 on known working board)
i2c_cam_sda pin10 0.725
i2c_cam_sda pin11 0.726
PP5V pin12 0.434 (5v is present)
this is an SMC problem right,??
cant be u3900 since the camera is working. does SMBus talk to u3900??
Alan.L
mmm, think i've found the problem.
I've removed U5620, pin9 and pin10 has no continuity to u5800
Alan.L
fixed
u5800
to scl and sda test points
Inwerp
what glue did you use? still looking for something which fixes fast enough but does not glue my fingers together like cyanoacrylate
