820-00165 water damage
Hi, I´m working on this board, was liquid damage
PP3V3_G3H=8.58v
pp3v42_g3h=3.4v
pp3v3_S5=3.35V
PP5V_S0=5.15
L3095=0V
L7701=0V
Fan spin ok
I checked it with thermal camera and found out that U4500 got very hot 5 seconds after connected with the charger and no battery, should be replaced?, how I can check if this IC its ok?
Don't be so sure; read this...
I put it all together and when i push the power button now it shows on the screen battery icon with low red battery at 20.13v and 0.047 A to 0.615 A and then its turn off and no green or yellow light on the charger
ok , I started in SMC bypass mode and the laptop start normally with the fan at max speed, and when I restarted shows the same screen with the low battery sign, so what do you suggest?
20V power for an Air, why???
Don't you have original 45W Magsafe 2 charger?
It should work with 60/85W too, but none of them will send out 20V!!!
Use original charger, or lab PSU with less than 18V; preferible 15-16V.
20V triggers SMC_DCIN_VSENSE.
This is the reason why machine starts in SMC bypass only.
ok, I use now a 60W MacSafe2 and PPDCIN_G3H= 16.53v and PP5V_S4RS3=5.16v but no green or yellow light and shows the screen with the low battery
What is the exact PPBUS_G3H voltage?
Check it w/ and w/o battery connected.
Did you try known good LIO board/flex?
changed the LIO board/flex for a new one and Its work OK!! the USB-C tester with one T-tip adapter from china sucks!
Men, you are the BEST! thank you very much!
