820-00165 Won't finish booting
No-Clean
Clean board, already tried clean ME, different SSD with clean install of MacOS and the result is the same, Mac chimes, bar starts to load and sometimes it may get to the end but OS never loads, starting in recovery mode same thing.
When staring in Verbose mode gets stuck in: " In memory Panic Stackshot Succeded" .... Attempting system restart
No-Clean
Full BIOS with clean ME same problem.
Booting into Windows tries to star but soon after I get Your PC ran into a problem and needs to restart....
No-Clean
Installed new RAM, all 4 chips, also new EFI chip with clean BIOS, same problem still even in Windows and safe mode same exact problem :cry:
There is a modded ASD for this machine.
Not sure if helps in this case, but you can try.
I suspect CPU...
No-Clean
Thanks, I have the regular ASD, I will check if I can get the modded one.
I think it is the CPU as it gets really hot quickly.
