820-00165 Works until you plug in battery
bjf
This came to us with the smallest amount of corrosion on C5126. I replaced that and U5110. Entire area around SMC, and entire rest of board, was clean. The computer works fine until you plug a battery in. After that the MagSafe light either stays orange or doesn't come on and the computer won't turn on. Any ideas? I'm not sure what would cause this.
CRC2018
Based upon the assumption you are trying a known good battery:
1) Check PPBUS Voltage is normal
2) check inside the battery connector on the board for any corroded pins - i've seen liquid move down the cable from the battery before and corrode the connector inside.
3) Check R5380, R5381 and R6950
"BMON is at 1.1V and then goes up to 8.59 if I keep the probe on it for a few seconds."
Are you sure?
CHGR_BMON should be lower than 0.5V without battery.
Now you get stable SMC_RESET_L?
bjf
Sorry, no, I was still looking at BGATE. BMON is at .63V without battery, and .50V with battery. And yes, I'm getting stable SMC_RESET_L now - with and without battery plugged in - ever since I measured 3V42 and it came back on. Something is unstable on this and appears to be intermittently failing. The liquid-damage was extremely minimal though so it's hard to know what's happening.
bjf
Any idea what would cause SMC_RESET_L to get pulled down like that? I had assumed U5110 but what you're thinking is that it was just the SMC doing it?
U7100, SMC and U5110 are connected there.
Corrosion at J6100 can also affect SMC_RESET_L.
Also voltages at pins 4, 6, 7 of U5110 are important; so components connected there should be checked too.
bjf
Thanks, I can't invest the time to reball the SMC but I changed everything around U5110, including a different U5110. We'll see if it holds up. If not I'll sell it as-is to someone who has time to pull the SMC.
