820-00165
suzukigsxr1000r
Yes had liquid damage .
voltage on PPBUS close to 0 , no short to gorund .
when inject 8.6v to PPBUS the board is works and fan spin .
checked all the PPBUS Rails they looks good .
have green light on the charger and pp3v42 is 3.4v .
JohnB8812
That is LITERALLY impossible lmao you can't have 0 volts on PPBUS and the machine turn on.......what is PPBUS without the battery plugged in just the charger?
suzukigsxr1000r
As I mentioned I injecued 8.6 volt from the power supply and the board turns on . I did not say it is turn on without PPBUS .
Without battery plugged I get 0.3 v
suzukigsxr1000r
Sorry my bad we have so many boards here which made me confused
This one yes work only with charger and shows x on the battery .
maybe ISL is bad ,will replace it tomorrow and update you .
but another board 820-00165 that has 0.3 volt on the PPBUS
has green light on the charger and no short to the ground
when i inject 8.6 v from power supply it is turning on .
missing PPBUS
JohnB8812
Ok so start another thread for that board to keep them straight. We can help with both. On this board, either bad ISL or bad SMC causing the X for the battery.
