820-00165
Neil250
Green light
No fan spin
No water damage
Board just "suddenly would not turn on"
PP1V2_S3 = 0 V
U7400 with lots of white corrosion
L7430: 0.30 V on diode mode to ground
PP5V5_S5: 5.5V
change U7400?
Clean the corrosion, replace damaged components and rebuild traces.
Do you get 3V3_S5/SUS?
U7400 requires PM_SLP_S4_L to work, do not change it yet.
Neil250
PP3V3_SUS: 3.345V
PP3V3_S5: 3.346V at R2042
PM_SLP_S4_L measured at R8111 pin 1: 3.335
Neil250
I think this U7400 is f'd
12: 5.14 V
16: 0
17: 0
18: 0
19: 0
20: 0.029
12: 5.14
DIODE:
1: short
3: short
4: GND
16: SHORT
17: SHORT
There is hardly any solder (almost none) at 16 and 17, all corroded away.
"Clean the corrosion, replace damaged components and rebuild traces."
Resolder all U7400 pads also.
If still short somewhere, replace the chip.
