820-00165
3V3_S5 is present?
No 12MHz pulse detected when pressing power button?
What is the actual problem of your machine?
So 12MHz oscillator is OK.
Resolder U1950 and remove Q8150; test again the board.
VCORE pulsing too?
Check PLT_RESET_L also.
Test starting in SMC bypass mode.
Try to post accurate information.
Voltages pulsing 1, 2 times, or every few seconds?
tech
voltage pulsing 2 times
VCORE pulsing too
also PLT_RESET_L pulsing
in normal condition
We discussed many times two pulses symptom on 00165 board.
You should know all to check now.
It is the worst scenario for this board...
