This board came in for no power; PPBUS was shorted, inject 1V and took off the bad cap, which was C7324.. now PPBUS is clear of short.
But the board is still not powering on; after visual inspection I found out that had corrosion on pin #2 and #3.. I replaced the chip and the board is still refusing to power on..
Although the symptoms are different where I get a fan spin.. then stop.. then a continuous fan spin.. if I unplug and replug.. I get no fan whatsoever..
When then fan spins I get PP1V05_S0.. Any clue on where to look?
