820-00165
No-Clean
Clean board.
Already reballed SMC as it looked like it had some corrosion but it was pretty clean.
PPBUS_G3H -> 8,56V
PPVRTC_G3H -> 3,3V
ALL_SYS_PWRGD -> 0V
PP5V_S5 -> 5V
PP3V3_S5 -> 3,3V
PP3V3_SUS -> 3,3V
When I Trigger SMC_ONOFF_L and check for drop pulse at PM_PWRBTN_L (at same time), But sometimes PM_PWRBTN_L will stay at 1.4V, most of the times comes back to 3.4V.
I don't get a pulse on PM_SLP_S4_L when I repeat the SMC_ONOFF_L trigger and it is 0V, if I try multiple times I may get a random pulse.
SMC bypass same thing.
PM_PWRBTN_L should drop to 0V, when SMC controls it.
You may have problems with this SMC; try changing it.
Also check PM_RSMRST_L level.
New SMC:
When I Trigger SMC_ONOFF_L and check for drop pulse at PM_PWRBTN_L (at same time) I do get a drop from 3.4V to 0V
When I Trigger SMC_ONOFF_L and check for drop pulse at PM_SLP_S4_L (at same time) I do get a very fast pulse from 0V to 2.7V hard to catch with multymeter
When I Trigger SMC_ONOFF_L and check for drop pulse at PM_RSMRST_L (at same time) I do get a drop from 3.3V to 0V
Also seems like most other rails pulse too.
PM_RSMRST_L must stay always high.
Don't you have steady 3V3_S5/SUS?
"check for drop pulse at PM_SLP_S4_L"
Never!
You should catch the pulse (low to high), as you mentioned above.
All big coils pulsing?
Test SMC bypass.
Ok lets start over:
3V3_S5/SUS Both steady no pulse
PM_RSMRST_L 3.3V
SMC Bypass same thing
Big coils pulse ONLY when I trigger SMC_ONOFF
"Big coils pulse"
All of them, including CPU core???
What about PLT_RESET_L?
PM_RSMRST_L still dropping?
Coils pulsing:
PP5V_S4RS3
PPDDR_S3_REG_R
PP1V05_S0_REG_R
No pulse:
PPVCC_S0_CPU_PH2
CPU Code no pulse
And remember this are steady:
PPBUS_G3H -> 8,56V
PPVRTC_G3H -> 3,3V
ALL_SYS_PWRGD -> 0V
PP5V_S5 -> 5V
PP3V3_S5 -> 3,3V
PP3V3_SUS -> 3,3V
U1950 clean, did a reball/reflow just in case, same thing
PLT_RESET_L 0V steady
PM_RSMRST_ 3.2V steady
Removing Q8150 same thing
Tied together pins 5 & 6 of U1950 same thing and no pulse either on L7310/20.
No pulse at L7310/20 before or after the above changes
Check U7200 basic power and signals: pins 17, 16, 1.
Also check all SPI Bus Series Termination resistors and their traces.
Inspect J6100 for corrosion.
