820-00239 A1706 'Critical Update Required and no touchbar
Roshon
We've got a A1706 with no touchbar that is failing to'Critical update.
Also tested the board in a different housing and still the same error.
Not sure where to check next.
Just to add that the Macbook boots in safe mode
Any history available?
Check voltages and signals on both touchbar connectors.
Find proper test points on boardview.
Compare readibgs with good board, if possible.
Roshon
I GET 5V ON PIN 22 PP5V_SO_T139 pin 21 1.8v
PIN 20 PP1V8_SOSW_DFR 1.1V pin 19 1.1v
PIN 18 1.8V
PIN 16 1.8V
PIN 14 1.8V
PIN 2 dfr_touch_lid 0v
"PIN 20 PP1V8_SOSW_DFR 1.1V"
Are you sure?
As per schematic, pins 20 & 21 are tied together.
Check J4401 too...
