no image, cpu gets warm no chime . Touchpad vibrates but keyboard light does not come on. Board are clean. can't turn on dfu
L7410/20/30 and L3500 0v
PLT_RST_L 3.3v
R3090/98 are ok
Don't expect iGPU voltage untill high graphics load is detected.
L3500 should have 5V only when USB device is inserted into corresponding ports.
If PLT_RST_L goes high, power on sequence has been completed; including CPU core voltage.
The board should be able to enter DFU.
Be sure to follow all the steps from tutorial.
