820-00239 Touch does not work
iClub
This mac has a bubble on Flat J4402, I replaced the Topcase along with touch bar, in testing it worked, but then it stopped. I replaced the Q4400, but it didn't work. The LCD in the Bar Works.
So you get backlight on touchbar, but no image, nor reaction to touch on it?
Did you test with another known good touchbar?
iClub
Exactly.
I tested it with two Topcases and it works perfectly.
Shouldn't it be 1.8V on pin 20/21? I am testing with the Flat touch disconnected and the LCD of the BAR connected.
Check U4404 for I/O short.
"I tested it with two Topcases and it works perfectly."
Works correctly what, the main board???
