820-00244-A
iFix
Hi guys.
I have this board with no power issue. It had a short on PPBUS_G3H specifically U7210 was burned and I replaced it, but also before that as i was following the short i took out U7000 and then resoldered it. Now the short in gone but it's stuck on 5v. I have all the LDO lines on U3100(CD3215A)... Any ideas?
Thanks 🖖
it-solve
if overvoltage went through short u7210 most likely you will have shorted these pins on your burned ic.
That can be probably a quick check for a dead cpu :/
